跳转到主内容
Weinmann VENTImotion and VENTIlogic Power Board Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
  1. Weinmann VENTImotion and VENTIlogic Power Board Replacement, Power Board: 步骤 1 中的图像 1,2 Weinmann VENTImotion and VENTIlogic Power Board Replacement, Power Board: 步骤 1 中的图像 2,2
    • Open the Device by following these steps:
    • Open the device only with the power supply plug disconnected.
    • Place the device on a non-slip surface with the top facing downwards.
    • Remove the filter cassette from the top part of the housing
    • Undo and remove the 6 screws (34)
    • Open the bottom part of the housing (35) away to the side.
    • Undo the connecting cables for the humidifier (42) and the alarm (43)
    • You can now put the bottom part of the housing (35) to one side.
  2. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 步骤 2 中的图像 1,1
    • Disconnect the power board connecting cable (45) from the power board (41).
  3. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 步骤 3 中的图像 1,1
    • Disconnect the Motor Cable
  4. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 步骤 4 中的图像 1,1
    • Disconnect the O2 valve/power board connecting cable (70) from the power board.
    • Disconnect all connecting cables from the control board.
    • Remove the power board from the top part of the housing.
  5. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 步骤 7 中的图像 1,1
    • Take the rechargeable battery connecting cable (48) out of the groove and disconnect it from the power board (41).
  6. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 步骤 8 中的图像 1,1
    • Disconnect the cables of the old power board and plug them into the appropriate slots of the new power board 41:
    • –power board/control board connecting cable (46)
    • –rechargeable battery connecting cable (48)
    • –earth cable (47)
  7. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 步骤 9 中的图像 1,2 Weinmann VENTImotion and VENTIlogic Power Board Replacement: 步骤 9 中的图像 2,2
    • Connect the power board/mains supply unit connecting cable (45) to the new power board.
    • Position the new power board in the top part of the housing.
  8. Weinmann VENTImotion and VENTIlogic Power Board Replacement: 步骤 11 中的图像 1,1
    • Restore the connections to the control board.
结论
另外一个人完成了本指南。
Emily Jacobson
于04/06/20注册
288 声望
撰写一个指南
团队
Cal Poly, Team S7-G19, Paton Spring 2020 Cal Poly, Team S7-G19, Paton Spring 2020 的会员
CPSU-PATON-S20S7G19
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 212
