跳转到主内容
Weed Whacker Line Replacement
  1. Weed Whacker Line Replacement, Line: 步骤 1 中的图像 1,3 Weed Whacker Line Replacement, Line: 步骤 1 中的图像 2,3 Weed Whacker Line Replacement, Line: 步骤 1 中的图像 3,3
    • Remove cutting line guard from weed whacker. This is usually attached by a wing-nut or a bolt and nut, so it can be removed either by hand or with the correct sized wrench.
  2. Weed Whacker Line Replacement: 步骤 2 中的图像 1,1
    • Flip weed whacker upside down so that bottom of cutting piece is facing up.
  3. Weed Whacker Line Replacement: 步骤 3 中的图像 1,1
    • There will be a bottom cap of the rotor setup that needs to be removed. In some models this will be held on with a nut and bolt fixture, but in many models there will be a circular cap that can be rotated counter clockwise for removal. Remove this piece in the manner necessary.
  4. Weed Whacker Line Replacement: 步骤 4 中的图像 1,2 Weed Whacker Line Replacement: 步骤 4 中的图像 2,2
    • Once the bottom piece is removed, there will be another circular piece that may or may not have cutting line coiled around it. Remove this piece from the weed whacker.
  5. Weed Whacker Line Replacement: 步骤 5 中的图像 1,2 Weed Whacker Line Replacement: 步骤 5 中的图像 2,2
    • There should be slots to coil cutting line around, with a hole in each for line to be anchored. If no line is coiled around the part, insert the end of about three feet of cutting line into each of the holes, and coil the cutting line snugly around the part, making sure that there are no tangles in the line.
  6. Weed Whacker Line Replacement: 步骤 6 中的图像 1,1
    • If there are plastic tabs on the plastic part to hold the cutting line, insert each line into one these tabs. Leave approximately a foot of each line hanging out from the coils.
  7. Weed Whacker Line Replacement: 步骤 7 中的图像 1,2 Weed Whacker Line Replacement: 步骤 7 中的图像 2,2
    • On the weed whacker rotor, there will be eyelets for the cutting line to be fed through. Feed each line through each of these eyelets, being careful not to let the line come uncoiled.
  8. Weed Whacker Line Replacement: 步骤 8 中的图像 1,1
    • Replace the plastic piece with the cutting lines back onto the rotor, being sure that the coils remain in place, and the lines remain in place through the eyelets.
  9. Weed Whacker Line Replacement: 步骤 9 中的图像 1,1
    • Replace the cap that was removed at the beginning of the assembly.
  10. Weed Whacker Line Replacement: 步骤 10 中的图像 1,2 Weed Whacker Line Replacement: 步骤 10 中的图像 2,2
    • Replace the cutting line guard.
终点
2等其他人完成本指南。
Hannah Akey
于10/02/17注册
191 声望
撰写一个指南
团队
Michigan Tech, Team S5-G10, Galliah Fall 2017 Michigan Tech, Team S5-G10, Galliah Fall 2017 的会员
MTU-GALLIAH-F17S5G10
2 名成员
创作了1篇指南
1指南评论
It spins besept not with enough power to cut the grass why is
Mercedes Bush - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 851
