跳转到主内容
Water damage
  1. Water damage, Disassemble the primary frame: 步骤 1 中的图像 1,2 Water damage, Disassemble the primary frame: 步骤 1 中的图像 2,2
    • Use a piece of plastic, like a credit or store card, to open up the case.
  2. Water damage, Detach the secondary frame: 步骤 2 中的图像 1,3 Water damage, Detach the secondary frame: 步骤 2 中的图像 2,3 Water damage, Detach the secondary frame: 步骤 2 中的图像 3,3
    • Lift the cover with a plastic card and carefully pull it off.
    • Tip: The glue is very strong, so I recommend helping things along with the plastic card.
    • If you remove the cover slowly and don't stick the plastic card in too far, you might be able to re-use the strip of glue.
  3. Water damage, Detach display and mainboard: 步骤 3 中的图像 1,2 Water damage, Detach display and mainboard: 步骤 3 中的图像 2,2
    • Loosen the seven 20mm T5 screws.
    • Then slide the display upwards.
  4. Water damage, Disconnect the battery: 步骤 4 中的图像 1,1
    • Now the battery can be disconnected and replaced, if necessary.
  5. Water damage, Detach the display cable: 步骤 5 中的图像 1,1
    • This Kindle has water damage which corroded the display cable.
    • I think changing the display is not possible because it is glued to the mainboard, possibly even soldered. I won't try replacing it because I only need to clean the display connector.
结论
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Lukas Wolf
于02/17/24注册
121 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 53
总计 601
