跳转到主内容
Uninstalling an Electric Water Heater
你所需要的
  1. Uninstalling an Electric Water Heater, Water Heater: 步骤 1 中的图像 1,1
    • At the breaker box, locate the breaker for the water heater. Switch the breaker bar to the off position.
    • Using a multimeter, check the line voltage at the water heater. The multimeter should read "0 VAC."
  2. Uninstalling an Electric Water Heater: 步骤 2 中的图像 1,2 Uninstalling an Electric Water Heater: 步骤 2 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the access panel (or panels) to access the thermostat and element.
    • Some electric water heater models may have only one access panel, located near the bottom of the tank. Some may have two— both an upper and lower access panel.
    • Set aside the access panel cover and screws. Remove the insulation to expose the wires, thermostat, and element.
    • Disconnect the wiring from the electrical components in the panel.
  3. Uninstalling an Electric Water Heater, Draining the tank: 步骤 4 中的图像 1,1
    • Attach a hose to the drain valve located at the bottom of the tank, near the lower access panel. Place the other end of the hose in a safe location for the water to drain.
    • Open the drain valve on the water heater by turning it counter-clockwise.
    • Once you have a steady flow of water coming out of the hose, slowly close the cold water valve to the water heater by turning it clockwise.
    • If the water flow slows down, you can open a sink or tub faucet to help the tank drain quicker.
  4. Uninstalling an Electric Water Heater: 步骤 5 中的图像 1,1
    • Using adjustable pliers, disconnect the water lines from the tank.
    • If the lines are glued in place, you will need to use a steel wire saw to disconnect the water line.
  5. Uninstalling an Electric Water Heater: 步骤 6 中的图像 1,2 Uninstalling an Electric Water Heater: 步骤 6 中的图像 2,2
    • Using a pipe wrench, detach all remaining pipes from the tank.
  6. Uninstalling an Electric Water Heater: 步骤 7 中的图像 1,1
    • Remove the water tank.
    • The tank will have sediment and some water in it. It will be heavy and require at least 2 people to move it safely.
    • To install a new water heater, follow the manufacturer's installation instructions included with the new appliance.
结论
To install a new water heater, follow the manufacturer’s installation instructions provided with the new water heater.
2等其他人完成本指南。
Lindsay Martin
于09/20/17注册
178 声望
撰写一个指南
团队
一条评论
If you have enough assistance to transport the unit outside the house, taking apart an old water heater is simple. Components, mounting hardware, and other aspects of a water heater can all be removed independently. Nonetheless, it takes strength to pull the old water from its place and move it outside for proper disposal.
Juliet Cyrus - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 38
过去 30 天: 121
总计 4,628
