简介
本指南将指导您如何为水舞音响从底部塞子处重新注水。这些水扬声器有通过底部水塞泄漏的潜在可能性。 本指南将逐步向您展示如何将扬声器拆开,以便用强力胶水替换水塞。 我们之所以用强力胶替代它,是因为这种胶可以更有效地密封孔,这是一个简单的过程。
你所需要的
您的水舞音响可以继续使用了,感谢您使用本指南。
47等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
35条评论
the pump is defective how to replace
anpicard@videotron.ca
I couldnt get plug out either so I drilled a hole in back and filled it with mineral water and sealed it with a small strip of scotch tape and duct tape on top of that in case I had to get back in. It works, but now it looks different. Sometimes the water clings to the inside and it looks a little foggy. Is it mineral water, or mineral oil? If it leaks again I'll prob try the oil.
The original liquid has a lower surface tension than water. I used odorless mineral spirits.
If the pump is noisy, try a drop of oil in the motor.
aeromojito - 回复
That means that the speakers are broken. You might need to replace it. If not, then its a probelm with the board, which I have no idea how to fix.
