你所需要的
Pry off the 4x bottom feet
Unscrew the 4 screws under the feet #2
Pull away the bottom
Remove 3 screws circled in picture
Pull circuit board away from top
在这个步骤中使用的工具:Desoldering Pump$3.99
I had to cut away some glue between the circuit board and the pin
Removed the pin by touching solder joint with iron and pulling pin out
Remove excess solder. I used a solder sucker
I used tape to hold the pin in the correct spot
Then just added solder to the via from the bottom
Remove tape (Masking tape was a little to strong but I got it off)
The replacement pin I used was: https://www.sparkfun.com/products/9174
