跳转到主内容
加入维修社区 - 创建账户
Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement
你所需要的
    1. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
      • The screws in the rubber legs of the burner do not need to be removed.
      • If the back panel has never been opened before, the screws may be more difficult to unscrew.
      询问修复机器人
      添加评论
    2. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: 步骤 2 中的图像 1,2 Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: 步骤 2 中的图像 2,2
      • Using a wrench, remove the bolt from the center of the back panel.
      询问修复机器人
      添加评论
    3. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement: 步骤 3 中的图像 1,1
      • The back panel can now be easily lifted off.
      询问修复机器人
      添加评论
    1. Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Plastic Leg and Rubber Stoppers: 步骤 4 中的图像 1,2 Waring Pro SB30 Plastic Leg and Rubber Stoppers Replacement, Plastic Leg and Rubber Stoppers: 步骤 4 中的图像 2,2
      • While using the wrench to hold the bolt, use the screwdriver to remove the screw.
      • The leg is two separate pieces, the plastic leg and rubber stopper.
      • Careful not to lose the bolts and washers as they are very small.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Sun Fai Lau
于09/22/14注册
588 声望
创作了5篇指南
团队
USF Tampa, Team 10-7, Brown Fall 2014 USF Tampa, Team 10-7, Brown Fall 2014 的会员
USFT-BROWN-F14S10G7
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 505
