跳转到主内容
Waring 51BL29 Power Cord Replacement
你所需要的
  1. Waring 51BL29 Power Cord Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Waring 51BL29 Power Cord Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Power Cord Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom panel.
  3. Waring 51BL29 Power Cord Replacement, Drive Coupling: 步骤 3 中的图像 1,1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Power Cord Replacement: 步骤 4 中的图像 1,1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Power Cord Replacement: 步骤 5 中的图像 1,1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
  6. Waring 51BL29 Power Cord Replacement, Motor: 步骤 6 中的图像 1,2 Waring 51BL29 Power Cord Replacement, Motor: 步骤 6 中的图像 2,2
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
  7. Waring 51BL29 Power Cord Replacement: 步骤 7 中的图像 1,1
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
  8. Waring 51BL29 Power Cord Replacement: 步骤 8 中的图像 1,3 Waring 51BL29 Power Cord Replacement: 步骤 8 中的图像 2,3 Waring 51BL29 Power Cord Replacement: 步骤 8 中的图像 3,3
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
  9. Waring 51BL29 Power Cord Replacement, Power Cord: 步骤 9 中的图像 1,1
    • Remove the black power cord.
结论
Quinn Vu
于04/17/17注册
113 声望
撰写一个指南
团队
Cal Poly, Team S15-G4, Banghart Spring 2017 Cal Poly, Team S15-G4, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S15G4
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 16
总计 1,769
