跳转到主内容
Waring 51BL29 Motor Replacement
你所需要的
  1. Waring 51BL29 Motor Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Waring 51BL29 Motor Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Motor Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom panel.
  3. Waring 51BL29 Motor Replacement, Drive Coupling: 步骤 3 中的图像 1,1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Motor Replacement: 步骤 4 中的图像 1,1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Motor Replacement: 步骤 5 中的图像 1,1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
  6. Waring 51BL29 Motor Replacement, Motor: 步骤 6 中的图像 1,2 Waring 51BL29 Motor Replacement, Motor: 步骤 6 中的图像 2,2
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
  7. Waring 51BL29 Motor Replacement: 步骤 7 中的图像 1,1
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
  8. Waring 51BL29 Motor Replacement: 步骤 8 中的图像 1,3 Waring 51BL29 Motor Replacement: 步骤 8 中的图像 2,3 Waring 51BL29 Motor Replacement: 步骤 8 中的图像 3,3
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
结论
Dean Becker
于04/17/17注册
470 声望
创作了4篇指南
团队
Cal Poly, Team S15-G4, Banghart Spring 2017 Cal Poly, Team S15-G4, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S15G4
4 名成员
创作了5篇指南
一条评论
Hi
Where do I source a replacement motor? I have been looking without success for UK supplier. Thanks Jill
I have a much loved Vintage Waring blender …
Jill Lancaster - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 2,505
