跳转到主内容
Waring 51BL29 Drive Coupling Replacement
你所需要的
  1. Waring 51BL29 Drive Coupling Replacement, Bottom Panel: 步骤 1 中的图像 1,2 Waring 51BL29 Drive Coupling Replacement, Bottom Panel: 步骤 1 中的图像 2,2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Drive Coupling Replacement: 步骤 2 中的图像 1,1
    • Remove the bottom panel.
  3. Waring 51BL29 Drive Coupling Replacement, Drive Coupling: 步骤 3 中的图像 1,1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Drive Coupling Replacement: 步骤 4 中的图像 1,1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Drive Coupling Replacement: 步骤 5 中的图像 1,1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
结论
4等其他人完成本指南。
Dean Becker
于04/17/17注册
470 声望
创作了4篇指南
团队
Cal Poly, Team S15-G4, Banghart Spring 2017 Cal Poly, Team S15-G4, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S15G4
4 名成员
创作了5篇指南
一条评论
Do you happen to know where I can purchase this replacement part?
Jessica Dye - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 15
过去 30 天: 44
总计 4,289
