简介
The bottom panel is simply the thin circular metal covering on the bottom of the blender that hides the motor and electrical components. This guide will show you how to remove it so that you can get to the blender's inner components.
你所需要的
Turn the blender on its side so the bottom panel is facing you.
Unscrew the 22mm Phillips #1 screw on the indent of the panel.
Unscrew the 3 screws in the rubber holes.
即将完成!
结论
