跳转到主内容
Wand Company Star Trek Communicator Silver Plate Replacement
你所需要的
  1. Wand Company Star Trek Communicator Silver Plate Replacement, Silver Plate: 步骤 1 中的图像 1,1
    • Power off the Star trek Bluetooth Communicator before disassembling.
  2. Wand Company Star Trek Communicator Silver Plate Replacement: 步骤 2 中的图像 1,2 Wand Company Star Trek Communicator Silver Plate Replacement: 步骤 2 中的图像 2,2
    • Remove the four T6 Torx screws (1.70mm) located on the back of the device.
    • Remove the black plastic cover by gently pulling it.
  3. Wand Company Star Trek Communicator Silver Plate Replacement: 步骤 3 中的图像 1,2 Wand Company Star Trek Communicator Silver Plate Replacement: 步骤 3 中的图像 2,2
    • Remove the protective foam located around the speaker and charging magnets.
    • Be careful not to lose the two magnets located between the microphone and the speaker. The magnets can be easily removed if they come in contact with other magnetic materials.
  4. Wand Company Star Trek Communicator Silver Plate Replacement: 步骤 4 中的图像 1,1
    • Remove the two Phillips PH0 (0.9mm) screws located to the side of each magnet.
  5. Wand Company Star Trek Communicator Silver Plate Replacement: 步骤 5 中的图像 1,1
    • Remove the black cover.
  6. Wand Company Star Trek Communicator Silver Plate Replacement: 步骤 6 中的图像 1,1
    • Remove the protective foam attached to the battery.
  7. Wand Company Star Trek Communicator Silver Plate Replacement: 步骤 7 中的图像 1,2 Wand Company Star Trek Communicator Silver Plate Replacement: 步骤 7 中的图像 2,2
    • Remove the five Phillips PH0 (0.9mm) screws located at the top and bottom of the silver plate.
  8. Wand Company Star Trek Communicator Silver Plate Replacement: 步骤 8 中的图像 1,1
    • Remove the silver plate.
结论
2等其他人完成本指南。
Garret Moses
于02/15/17注册
313 声望
创作了2篇指南
团队
USF Tampa, Team 5-6, Passmore Spring 2017 USF Tampa, Team 5-6, Passmore Spring 2017 的会员
USFT-PASSMORE-S17S5G6
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 7
过去 30 天: 13
总计 563
