跳转到主内容
加入维修社区 - 创建账户
Wall Outlet (Type F) Replacement
你所需要的
  1. Wall Outlet (Type F) Replacement, Turn off power: 步骤 1 中的图像 1,3 Wall Outlet (Type F) Replacement, Turn off power: 步骤 1 中的图像 2,3 Wall Outlet (Type F) Replacement, Turn off power: 步骤 1 中的图像 3,3
    • Find your Breaker Panel.
    • Identify the breaker to turn off.
    • There'll typically be a table listing the circuits corresponding to breakers.
    • Turn off the breaker.
  2. Wall Outlet (Type F) Replacement, Determine voltage absence: 步骤 2 中的图像 1,1
    • Use a Duspol or any other two-pole voltage tester to test if there is voltage at the contacts.
    • Do not work on live circuits if you are not an experienced professional.
  3. Wall Outlet (Type F) Replacement, Remove the old outlet cover: 步骤 3 中的图像 1,3 Wall Outlet (Type F) Replacement, Remove the old outlet cover: 步骤 3 中的图像 2,3 Wall Outlet (Type F) Replacement, Remove the old outlet cover: 步骤 3 中的图像 3,3
    • Remove the outlet cover by unscrewing the middle captive screw with flat head screwdriver.
    • Remove the frame.
    • If you can't remove the frame because there's a switch on the same frame, take a look at this guide, on how to remove the cover of a switch.
  4. Wall Outlet (Type F) Replacement, Remove the wall outlet: 步骤 4 中的图像 1,1
    • Loosen the holding claws by turning the two screws.
    • If your outlet is mounted inside a cavity wall box you can remove it by loosening the two screws around the perimeter and turning the switch until the two keyholes line up.
  5. Wall Outlet (Type F) Replacement, Disconnect the wires: 步骤 5 中的图像 1,1
    • Disconnect the wires form the old outlet.
    • If the old outlet has Push-In contacts, you can unlock the terminals by pushing down on the clear plastic levers.
    • If you short Earth to Neutral you'll trigger your GFCI/RCD even if the power is off.
    • Connect the wires to the new outlet.
    • There is no rule on where to connect the Phase Conductor, but it's usually considered best practice to connect it on the right side, as it makes it easier for electricians to test the outlet with a Duspol.
  6. Wall Outlet (Type F) Replacement, Mount the outlet: 步骤 7 中的图像 1,3 Wall Outlet (Type F) Replacement, Mount the outlet: 步骤 7 中的图像 2,3 Wall Outlet (Type F) Replacement, Mount the outlet: 步骤 7 中的图像 3,3
    • Mount the outlet by following the previous steps in reverse.
  7. Wall Outlet (Type F) Replacement, Turn the power back on: 步骤 8 中的图像 1,1
    • Turn the power back on.
  8. Wall Outlet (Type F) Replacement, Test the new outlet: 步骤 9 中的图像 1,3 Wall Outlet (Type F) Replacement, Test the new outlet: 步骤 9 中的图像 2,3 Wall Outlet (Type F) Replacement, Test the new outlet: 步骤 9 中的图像 3,3
    • Measure across Hot and Neutral.
    • You want 230V
    • Measure across Hot and Ground.
    • You want 230V
    • Measure across Ground and Neutral.
    • You want 0V
    • Apply load between Hot and Neutral by pressing the two large buttons.
    • If this trips your GFCI, you either swapped Ground and Neutral, or your Neutral belongs to a different GFCI than your Phase Conductor.
结论
2等其他人完成本指南。
Sebastian
于08/19/18注册
32,124 声望
创作了71篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 48
过去 30 天: 184
总计 3,682
