跳转到主内容
Wahl Professional Designer Power Switch Replacement
你所需要的
  1. Wahl Professional Designer Power Switch Replacement, Power Switch: 步骤 1 中的图像 1,2 Wahl Professional Designer Power Switch Replacement, Power Switch: 步骤 1 中的图像 2,2
    • Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
  2. Wahl Professional Designer Power Switch Replacement: 步骤 2 中的图像 1,2 Wahl Professional Designer Power Switch Replacement: 步骤 2 中的图像 2,2
    • Unscrew the two black 5.556 mm Phillip head screw on the power switch with a Phillips #0 Screwdriver.
  3. Wahl Professional Designer Power Switch Replacement: 步骤 3 中的图像 1,3 Wahl Professional Designer Power Switch Replacement: 步骤 3 中的图像 2,3 Wahl Professional Designer Power Switch Replacement: 步骤 3 中的图像 3,3
    • Shimmy the power switch off the mount until it is completely removed.
结论
团队
USF Tampa, Team S14-G5, Boczar Fall 2017 USF Tampa, Team S14-G5, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S14G5
2 名成员
创作了10篇指南
1指南评论
Hello Mrs/ms Swearengin, I’m disassembled my Wahl desingner I’m unable to make the power switch stiff . It’s very loose I can’t recall which screw goes in between two black 5.556 mm Phillip head screw or if it needs a screw at all
Carlos Olvera - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 796
