跳转到主内容
Wahl Lithium Ion Trimmer Motherboard Replacement
你所需要的
  1. Wahl Lithium Ion Trimmer Motherboard Replacement, Disassembling of Wahl Lithium Ion Trimmer: 步骤 1 中的图像 1,2 Wahl Lithium Ion Trimmer Motherboard Replacement, Disassembling of Wahl Lithium Ion Trimmer: 步骤 1 中的图像 2,2
    • Begin by removing the rubber grip along the handle.
  2. Wahl Lithium Ion Trimmer Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Wahl Lithium Ion Trimmer Motherboard Replacement: 步骤 3 中的图像 1,2 Wahl Lithium Ion Trimmer Motherboard Replacement: 步骤 3 中的图像 2,2
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
  4. Wahl Lithium Ion Trimmer Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Remove the motor, battery, and motherboard from the plastic casing.
  5. Wahl Lithium Ion Trimmer Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the white plastic piece and the wires from the motherboard.
    • If necessary, cut the wires as close to the motherboard as possible so that you can reconnect them to the new motherboard.
  6. Wahl Lithium Ion Trimmer Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the old motherboard and install the new one. Then, connect the wires and white piece to the new motherboard.
结论
nathan
于10/22/13注册
1,422 声望
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 3,497
