简介
If the blades to your Wahl Lithium Ion Trimmer are damaged or worn, this guide will show you how to replace them with functioning blades.
Blades can be damaged by being dropped, misused, or not being properly taken care of. In any of these circumstances, a replacement is typically required.
Because the blades are sharp, make sure to wear gloves or some sort of hand protection while handling the blades in order to avoid any sort of injury.
Before beginning this guide, make sure that the Wahl Lithium Ion Trimmer is powered off and disconnected from any source of electricity.
你所需要的
Examine the razor to identify any broken or jammed blades that require replacement. If any such blades are identified, the whole set must be changed.
Remove the metal clip using a Phillips #0 screwdriver.
Any chance of getting a clearer, closer, better lit shot of the assembled head? Mine has fallen apart, and this is the closest I have found to a picture of what it should look like. If only it were clearer...
Separate the Wahl Lithium Ion Trimmer head into its four components. Remove the damaged blade and replace it with a new one.
how to put back spring?
Ok I am at that point how do I put it back together
3等其他人完成本指南。
