跳转到主内容
Wahl Lithium Ion Trimmer Metal Razor Arms Replacement
你所需要的
  1. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement, Metal Razor Arms: 步骤 1 中的图像 1,1
    • Examine the razor to identify any broken or jammed blades, if any the whole set must be changed.
  2. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 步骤 2 中的图像 1,1
    • Unscrew the two Phillips screws with a Phillips #0 screwdriver.
    • Set those two screws aside for reassembly.
  3. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 步骤 3 中的图像 1,1
    • Apply pressure to the back side of the blades while pushing outward to completely remove the blade head.
  4. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 步骤 4 中的图像 1,3 Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 步骤 4 中的图像 2,3 Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 步骤 4 中的图像 3,3
    • Put the Phillips #0 screwdriver in the opening and pry out the metal clip.
    • Set aside the metal clip for reassembly
  5. Wahl Lithium Ion Trimmer Metal Razor Arms Replacement: 步骤 5 中的图像 1,1
    • Separate the Wahl Lithium Ion Trimmer head into its four components.
    • Remove the damaged blade and replace it with a new one.
结论
4等其他人完成本指南。
nathan
于10/22/13注册
1,422 声望
创作了6篇指南
3条评论
Where can I get replacement arms?
Sam - 回复
Where can one obtain a new spring???
tinkrmann - 回复
The spring popped out of the head, but your pictures are too blurry to see how it goes back together.
Mark Wilson - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 40
总计 19,599
