简介
Cord problems are bound to eventually happen due to normal use, winding up the cord, and cramming it into a drawer. The cord replacement process is straight forward, but the most important part to remember is do not work on device while it is plugged in. It is also advisable to take advantage of the open device by cleaning out any visible debris.
你所需要的
Unscrew the three 12mm black JIS screw found on the red side of the the device with a JIS #1 driver.
To reassemble your device, follow these instructions in reverse order. When installing new cord, make sure black wire is underneath the white wire.
3等其他人完成本指南。
