跳转到主内容
Wahl Hair Clippers Model ST115VAC Power Cord Replacement
你所需要的
  1. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Unscrew the three 12mm black JIS screw found on the red side of the the device with a JIS #1 driver.
  2. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: 步骤 2 中的图像 1,1
    • Grab the red cover by the side and lift off the top piece.
  3. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: 步骤 3 中的图像 1,1
    • Unscrew the 5.556mm screw with a JIS #0 screwdriver. (Black Screw located at power switch)
  4. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Spudger
    $2.99
    购买
    • Insert the metal spudger between the wire connector and the device connector. The spudger should disengage a tension-like lock between both connectors, and once disengaged gently pry out the cord connection.
    • (Note-dependent on varying user conditions, the connection may be harder to remove and may involve more force or a gentle rocking to separate connection.)
    • When working with electronics, make to use an ESD safe tool, to avoid shock. Try using the black nylon spudger instead.
  5. Wahl Hair Clippers  Model ST115VAC Power Cord  Replacement: 步骤 5 中的图像 1,1
    • Remove the cord from the fixed position.
结论
To reassemble your device, follow these instructions in reverse order. When installing new cord, make sure black wire is underneath the white wire.
3等其他人完成本指南。
Julio Alvarado
于02/15/17注册
131 声望
撰写一个指南
团队
USF Tampa, Team 10-4, Remmell Spring 2017 USF Tampa, Team 10-4, Remmell Spring 2017 的会员
USFT-REMMELL-S17S10G4
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 27
总计 2,935
