跳转到主内容
Wahl Chrome Pro Power Switch Replacement
你所需要的
  1. Wahl Chrome Pro Power Switch Replacement, Case: 步骤 1 中的图像 1,1
    • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
    • Make sure your device is not connected to power before you begin.
  2. Wahl Chrome Pro Power Switch Replacement: 步骤 2 中的图像 1,1
    • Lift the bottom blade straight up from the device body to remove it.
  3. Wahl Chrome Pro Power Switch Replacement: 步骤 3 中的图像 1,1
    • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
  4. Wahl Chrome Pro Power Switch Replacement: 步骤 4 中的图像 1,1
    • Lift the base of blade assembly straight up off of the body.
  5. Wahl Chrome Pro Power Switch Replacement: 步骤 5 中的图像 1,1
    • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
  6. Wahl Chrome Pro Power Switch Replacement: 步骤 6 中的图像 1,1
    • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
    • This screw is located on the opposite side of the body from the switch.
  7. Wahl Chrome Pro Power Switch Replacement: 步骤 7 中的图像 1,1
    • Remove the spring on the side of the body using tweezers.
  8. Wahl Chrome Pro Power Switch Replacement: 步骤 8 中的图像 1,1
    • Pry the body case off of the device using a spudger.
  9. Wahl Chrome Pro Power Switch Replacement, Power Switch: 步骤 9 中的图像 1,1
    • Remove one 7.5 mm JIS #1 screw connecting the power cord to the switch base.
  10. Wahl Chrome Pro Power Switch Replacement: 步骤 10 中的图像 1,1
    • Remove one 7.5 mm JIS #1 screw connecting the wire to the switch base.
  11. Wahl Chrome Pro Power Switch Replacement: 步骤 11 中的图像 1,1
    • Remove the switch from device by lifting straight up from the device body.
结论
Holly Dunn
于11/09/17注册
104 声望
撰写一个指南
团队
IUPUI, Team S7-G3, Baechle Fall 2017 IUPUI, Team S7-G3, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S7G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 492
