跳转到主内容
加入维修社区 - 创建账户
Wacom Intuos4 Touch Ring Replacement
你所需要的
  1. Wacom Intuos4 Touch Ring Replacement, Casing: 步骤 1 中的图像 1,3 Wacom Intuos4 Touch Ring Replacement, Casing: 步骤 1 中的图像 2,3 Wacom Intuos4 Touch Ring Replacement, Casing: 步骤 1 中的图像 3,3
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Touch Ring Replacement: 步骤 2 中的图像 1,2 Wacom Intuos4 Touch Ring Replacement: 步骤 2 中的图像 2,2
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Touch Ring Replacement, Motherboard: 步骤 3 中的图像 1,2 Wacom Intuos4 Touch Ring Replacement, Motherboard: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Using tweezers, remove the yellow tape covering the three cable connectors.
  4. Wacom Intuos4 Touch Ring Replacement: 步骤 4 中的图像 1,2 Wacom Intuos4 Touch Ring Replacement: 步骤 4 中的图像 2,2
    • Lift the black plastic clip holding the flat wire to the connector with either tweezers or an iFixit opening tool.
    • Pull on the white plastic tab to disconnect the flat wire.
  5. Wacom Intuos4 Touch Ring Replacement: 步骤 5 中的图像 1,2 Wacom Intuos4 Touch Ring Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the motherboard from the casing.
    • If you're having trouble, don't force it. Make sure all cables are disconnected and all screws are removed.
  6. Wacom Intuos4 Touch Ring Replacement, Touch Ring: 步骤 6 中的图像 1,2 Wacom Intuos4 Touch Ring Replacement, Touch Ring: 步骤 6 中的图像 2,2
    • Remove the plastic tracking ball by lifting it up and out of its slot.
  7. Wacom Intuos4 Touch Ring Replacement: 步骤 7 中的图像 1,1
    • Use an iFixit opening tool to gently lift the circuit board from the slot.
    • If the touch ring doesn't come out immediately, do not force it or you may cause damage to the device. If it is difficult to remove, heat the front face of the touch ring to loosen the glue that holds it in.
结论
另外一个人完成了本指南。
Lillian Avery
于10/26/22注册
91 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-6, Botvin Fall 2022 UMass Dartmouth, Team 3-6, Botvin Fall 2022 的会员
UMASSD-BOTVIN-F22S3G6
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 338
