简介
Use this guide to replace the foam safety pad of a Wacom Intuos4.
This guide was created with a model PTK-640 Wacom Intuos4. Different models may vary in design.
你所需要的
Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
Use a spudger to safely remove the white and sliver pad without applying enough pressure to scratch the motherboard.
即将完成!
结论
