跳转到主内容
Wacom Bamboo Pen And Touch Disassembly
你所需要的
  1. Wacom Bamboo Pen And Touch Disassembly, Wacom Bamboo Pen And Touch Disassembly: 步骤 1 中的图像 1,2 Wacom Bamboo Pen And Touch Disassembly, Wacom Bamboo Pen And Touch Disassembly: 步骤 1 中的图像 2,2
    • Place the device facing bottom part up.
    • Make sure the working surface won't scratch the surface of the tablet
  2. Wacom Bamboo Pen And Touch Disassembly: 步骤 2 中的图像 1,2 Wacom Bamboo Pen And Touch Disassembly: 步骤 2 中的图像 2,2
    • Remove 4 rubber feet using a spudger or a pair of tweezers
    • Unscrew 4 #000 Phillips screws
  3. Wacom Bamboo Pen And Touch Disassembly: 步骤 3 中的图像 1,1
    • Use spudger or other prying tool to open the tablet.
    • The clips are located all around the perimeter of the tablet
    • The parts inside are attached to the top part of the device
  4. Wacom Bamboo Pen And Touch Disassembly: 步骤 4 中的图像 1,1
    • Remove the cable.
    • Do not pull the cable with force - it is soldered to the mainboard
  5. Wacom Bamboo Pen And Touch Disassembly: 步骤 5 中的图像 1,1
    • While the pen holder might seem permamently riveted, it can be removed and cleaned
    • Press firmly around the rivets to re-attach it
  6. Wacom Bamboo Pen And Touch Disassembly: 步骤 6 中的图像 1,3 Wacom Bamboo Pen And Touch Disassembly: 步骤 6 中的图像 2,3 Wacom Bamboo Pen And Touch Disassembly: 步骤 6 中的图像 3,3
    • Unclip 3 flex cable connectors
    • The clips are fragile.
    • Unlocked connector's latch is in vertical position.
    • Due to fragiility of flex cables, it's better to remove the adhesive strips only from the mainboard and leave the attached adhesvie strips to the flex cable as is.
  7. Wacom Bamboo Pen And Touch Disassembly: 步骤 7 中的图像 1,3 Wacom Bamboo Pen And Touch Disassembly: 步骤 7 中的图像 2,3 Wacom Bamboo Pen And Touch Disassembly: 步骤 7 中的图像 3,3
    • The mainboard is now loose and can be removed.
    • The mainboard contains a fuse, visible in the second image in the gallery.
    • Replacement of touch digitizer requires removing the top sticker.This procedure is not a part of this guide, and it might permamently destroy the working surface of the tablet.
    • USB Cable is soldered to the mainboard
结论
00004707
于07/23/20注册
1,055 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 22
过去 30 天: 41
总计 198
