简介
Use this guide to remove or replace the fuel petcock on a Wacker BS50-4AS REV 101 (2019) Vibrator/Rammer.
你所需要的
Firmly grip the base of the spark plug wire's connector and pull it away from the spark plug to disconnect it.
Use a 10 mm socket to remove the bolt securing the throttle assembly's ground wire.
Remove the ground wire.
Grip the throttle cable's black wire bullet connecter and pull to disconnect it from the engine.
Grab both ends of the throttle wires and feed them out, past the metal engine guard.
Use a pair of flush cutters to cut the cable tie securing the throttle wires together.
Move the throttle lever all the way into the SLOW position, towards the front of the device, to loosen tension on the throttle cable.
Use a Phillips driver to remove the screw securing the throttle cable to the actuator arm on the motor.
Use an 8 mm socket to remove the two bolts securing the throttle assembly to the frame.
Grip the throttle assembly from underneath and lower it down through its cutout in the frame.
Holding the throttle assembly in place, pull the throttle cable through the hole on the throttle lever.
Remove the throttle cable.
During reassembly, ensure the throttle cable guide shoulder is fully recessed into its section on the throttle assembly.
Place a rag or shop towel underneath the petcock fuel lines to prevent drips and spills from getting on the device.
Grip one of the clear fuel tubes near where it connects to the petcock and squeeze it completely closed.
Pull the tube directly away from the petcock nipple to remove it.
Disconnect the second fuel tube from the petcock.
Thread the throttle wires out from underneath the metal engine guard.
Remove the throttle assembly.
Use a 3 mm hex key to remove the two bolts securing the petcock to the throttle assembly.
