简介
Use this guide to remove or replace the freezer door in your Whirlpool WRS315SDHW Refrigerator.
This guide replaces the entire freezer door as a unit.
你所需要的
Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the freezer door wiring harness.
Use a 1/4 inch socket wrench to remove the 16.2 mm-long screw securing the freezer door water hose.
Pull the wiring harness out of its slot in the chassis to access its connectors.
Disconnect the two connectors attached to the door wiring harness.
Use one hand to compress the blue plastic ring into the green section of the hose.
Use the other hand to pull the white water tube out of its slot.
Use a 3/16 inch Allen wrench to remove the two 19.3 mm-long screws securing the freezer door.
Pull the door hinge straight up to separate its alignment pins from the chassis.
Remove the door hinge.
Pull the freezer door straight up to disconnect it from the chassis.
Thread the cables through their slot in the chassis.
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
