跳转到主内容
WRS315SDHW Door Seal Replacement
你所需要的
  1. WRS315SDHW Door Seal Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Door Seal Replacement, Open the doors: 步骤 2 中的图像 1,3 WRS315SDHW Door Seal Replacement, Open the doors: 步骤 2 中的图像 2,3 WRS315SDHW Door Seal Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Door Seal Replacement, Disconnect the door seal: 步骤 3 中的图像 1,3 WRS315SDHW Door Seal Replacement, Disconnect the door seal: 步骤 3 中的图像 2,3 WRS315SDHW Door Seal Replacement, Disconnect the door seal: 步骤 3 中的图像 3,3
    • Insert an opening tool, or a similar tool, between the door frame and the seal.
    • Pry up to separate the seal from its groove on the frame.
    • This may take significant force.
  4. WRS315SDHW Door Seal Replacement, Remove the door seal: 步骤 4 中的图像 1,3 WRS315SDHW Door Seal Replacement, Remove the door seal: 步骤 4 中的图像 2,3 WRS315SDHW Door Seal Replacement, Remove the door seal: 步骤 4 中的图像 3,3
    • Use your hand and the opening tool to peel the door seal away from the frame.
    • Repeat this process for the perimeter of the door seal until the seal is completely separated.
  5. WRS315SDHW Door Seal Replacement, Only the door seal remains: 步骤 5 中的图像 1,3 WRS315SDHW Door Seal Replacement, Only the door seal remains: 步骤 5 中的图像 2,3 WRS315SDHW Door Seal Replacement, Only the door seal remains: 步骤 5 中的图像 3,3
    • You're now left with the door seal.
    • During reassembly, perform the following:
    • Use a Jimmy, or a similar tool, to remove any sealing foam in the door frame groove.
    • Use a mild cleaning solution to fully clean the groove.
    • Reinstall your door by attaching the top edge first, then wrapping the seal around the frame's perimeter.
    • You'll hear the gasket lock into the seam.
    • You may have to stretch the seal a few inches at the final edge.
  6. WRS315SDHW Door Seal Replacement, Perform a seal test: 步骤 6 中的图像 1,3 WRS315SDHW Door Seal Replacement, Perform a seal test: 步骤 6 中的图像 2,3 WRS315SDHW Door Seal Replacement, Perform a seal test: 步骤 6 中的图像 3,3
    • To test if your replacement door seal is working, perform the following:
    • Open the door slightly and insert a clean, flat bill between the door seal and the frame.
    • Close the door and slowly drag the bill away from the device.
    • If the seal is tight, then you should feel a moderate amount of resistance in the bill.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 170
