跳转到主内容
WRS315SDHW Defrost Heater Replacement
你所需要的
  1. WRS315SDHW Defrost Heater Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Defrost Heater Replacement, Open the doors: 步骤 2 中的图像 1,3 WRS315SDHW Defrost Heater Replacement, Open the doors: 步骤 2 中的图像 2,3 WRS315SDHW Defrost Heater Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Defrost Heater Replacement, Remove the drawers: 步骤 3 中的图像 1,2 WRS315SDHW Defrost Heater Replacement, Remove the drawers: 步骤 3 中的图像 2,2
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Defrost Heater Replacement: 步骤 4 中的图像 1,2 WRS315SDHW Defrost Heater Replacement: 步骤 4 中的图像 2,2
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Defrost Heater Replacement, Unclip the evaporator cover: 步骤 5 中的图像 1,3 WRS315SDHW Defrost Heater Replacement, Unclip the evaporator cover: 步骤 5 中的图像 2,3 WRS315SDHW Defrost Heater Replacement, Unclip the evaporator cover: 步骤 5 中的图像 3,3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Defrost Heater Replacement, Remove the evaporator cover: 步骤 6 中的图像 1,3 WRS315SDHW Defrost Heater Replacement, Remove the evaporator cover: 步骤 6 中的图像 2,3 WRS315SDHW Defrost Heater Replacement, Remove the evaporator cover: 步骤 6 中的图像 3,3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Defrost Heater Replacement, Disconnect the defrost heater: 步骤 7 中的图像 1,3 WRS315SDHW Defrost Heater Replacement, Disconnect the defrost heater: 步骤 7 中的图像 2,3 WRS315SDHW Defrost Heater Replacement, Disconnect the defrost heater: 步骤 7 中的图像 3,3
    • Disconnect the two spade connectors attached to the defrost heater.
  8. WRS315SDHW Defrost Heater Replacement, Reposition the cable: 步骤 8 中的图像 1,3 WRS315SDHW Defrost Heater Replacement, Reposition the cable: 步骤 8 中的图像 2,3 WRS315SDHW Defrost Heater Replacement, Reposition the cable: 步骤 8 中的图像 3,3
    • Pull the defrost heater cable out from behind the evaporator.
  9. WRS315SDHW Defrost Heater Replacement, Unfasten the defrost heater bracket: 步骤 9 中的图像 1,1
    • Use a 1/4 inch socket wrench to remove the 16.5 mm-long screw securing the defrost heater bracket.
  10. WRS315SDHW Defrost Heater Replacement, Release the defrost heater bracket: 步骤 10 中的图像 1,2 WRS315SDHW Defrost Heater Replacement, Release the defrost heater bracket: 步骤 10 中的图像 2,2
    • Pull the defrost heater bracket up to release it from its slot in the chassis.
  11. WRS315SDHW Defrost Heater Replacement, Remove the defrost heater: 步骤 11 中的图像 1,3 WRS315SDHW Defrost Heater Replacement, Remove the defrost heater: 步骤 11 中的图像 2,3 WRS315SDHW Defrost Heater Replacement, Remove the defrost heater: 步骤 11 中的图像 3,3
    • Slide the defrost heater from under the evaporator.
    • You may need to pull one end at a time until it's completely removed.
  12. WRS315SDHW Defrost Heater Replacement, Only the defrost heater remains: 步骤 12 中的图像 1,1
    • You're now left with the defrost heater.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
nicO
于04/14/15注册
15,945 声望
创作了89篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 393
