跳转到主内容
WRS315SDHW Auger Motor Replacement
你所需要的
  1. WRS315SDHW Auger Motor Replacement, Safety precautions: 步骤 1 中的图像 1,1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Auger Motor Replacement, Open the doors: 步骤 2 中的图像 1,3 WRS315SDHW Auger Motor Replacement, Open the doors: 步骤 2 中的图像 2,3 WRS315SDHW Auger Motor Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Auger Motor Replacement, Remove the icemaker tray: 步骤 3 中的图像 1,2 WRS315SDHW Auger Motor Replacement, Remove the icemaker tray: 步骤 3 中的图像 2,2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. WRS315SDHW Auger Motor Replacement, Unfasten the icemaker assembly: 步骤 4 中的图像 1,2 WRS315SDHW Auger Motor Replacement, Unfasten the icemaker assembly: 步骤 4 中的图像 2,2
    • Use a 1/4 inch socket wrench to remove the three screws securing the icemaker assembly (shown with the assembly removed):
    • Two 23.9 mm-long screws
    • One 16.7 mm-long screw
  5. WRS315SDHW Auger Motor Replacement, Reposition the icemaker assembly: 步骤 5 中的图像 1,3 WRS315SDHW Auger Motor Replacement, Reposition the icemaker assembly: 步骤 5 中的图像 2,3 WRS315SDHW Auger Motor Replacement, Reposition the icemaker assembly: 步骤 5 中的图像 3,3
    • Pull the icemaker assembly toward the right edge of the refrigerator to release it from its slot in the chassis.
    • Let the icemaker assembly hang to access its connector.
  6. WRS315SDHW Auger Motor Replacement, Disconnect the icemaker assembly: 步骤 6 中的图像 1,3 WRS315SDHW Auger Motor Replacement, Disconnect the icemaker assembly: 步骤 6 中的图像 2,3 WRS315SDHW Auger Motor Replacement, Disconnect the icemaker assembly: 步骤 6 中的图像 3,3
    • Disconnect the spade connector attached to the icemaker assembly.
  7. WRS315SDHW Auger Motor Replacement, Remove the icemaker assembly: 步骤 7 中的图像 1,1
    • Remove the icemaker assembly.
  8. WRS315SDHW Auger Motor Replacement, Unfasten the icemaker auger assembly: 步骤 8 中的图像 1,1
    • Use a 1/4 inch socket wrench to remove the four screws securing the icemaker auger assembly:
    • Two 24.1 mm-long screws
    • Two 16.5 mm-long screws
  9. WRS315SDHW Auger Motor Replacement, Reposition the icemaker auger assembly: 步骤 9 中的图像 1,3 WRS315SDHW Auger Motor Replacement, Reposition the icemaker auger assembly: 步骤 9 中的图像 2,3 WRS315SDHW Auger Motor Replacement, Reposition the icemaker auger assembly: 步骤 9 中的图像 3,3
    • Pull the icemaker auger assembly off of its slot in the chassis.
    • Let the assembly hang to access its connector.
  10. WRS315SDHW Auger Motor Replacement, Disconnect the icemaker auger assembly: 步骤 10 中的图像 1,3 WRS315SDHW Auger Motor Replacement, Disconnect the icemaker auger assembly: 步骤 10 中的图像 2,3 WRS315SDHW Auger Motor Replacement, Disconnect the icemaker auger assembly: 步骤 10 中的图像 3,3
    • Use a flathead screwdriver, or a similar tool, to compress the connector attached to the icemaker auger assembly.
    • Use your hands to disconnect the assembly connector.
  11. WRS315SDHW Auger Motor Replacement, Remove the icemaker auger assembly: 步骤 11 中的图像 1,1
    • Remove the icemaker auger assembly.
  12. WRS315SDHW Auger Motor Replacement, Remove the auger fin: 步骤 12 中的图像 1,3 WRS315SDHW Auger Motor Replacement, Remove the auger fin: 步骤 12 中的图像 2,3 WRS315SDHW Auger Motor Replacement, Remove the auger fin: 步骤 12 中的图像 3,3
    • Twist the auger fin clockwise until it separates from the assembly.
    • Remove the auger fin.
  13. WRS315SDHW Auger Motor Replacement, Unfasten the grounding wire: 步骤 13 中的图像 1,1
    • Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 11.6 mm-long screw securing the grounding wire.
  14. WRS315SDHW Auger Motor Replacement, Unfasten the auger motor: 步骤 14 中的图像 1,1
    • Use a 1/4 inch socket wrench to remove the three 16.7 mm-long screws securing the auger motor.
  15. WRS315SDHW Auger Motor Replacement, Disconnect the auger motor: 步骤 15 中的图像 1,2 WRS315SDHW Auger Motor Replacement, Disconnect the auger motor: 步骤 15 中的图像 2,2
    • Use needle nose pliers, or your hands, to disconnect the grounding wire from the auger motor.
  16. WRS315SDHW Auger Motor Replacement: 步骤 16 中的图像 1,3 WRS315SDHW Auger Motor Replacement: 步骤 16 中的图像 2,3 WRS315SDHW Auger Motor Replacement: 步骤 16 中的图像 3,3
    • Disconnect the two spade connectors attached to the auger motor.
  17. WRS315SDHW Auger Motor Replacement, Only the auger motor remains: 步骤 17 中的图像 1,1
    • You're now left with the auger motor.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
nicO
于04/14/15注册
15,927 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
35 名成员
创作了603篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 135
