跳转到主内容
WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Knob Replacement
你所需要的
  1. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Knob Replacement, Pressure Regulator Knob: 步骤 1 中的图像 1,1
    • Using a 2mm Allen wrench, remove the Allen screw located on the pressure regulator knob on the back of the brad nailer.
  2. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Knob Replacement: 步骤 2 中的图像 1,1
    • Remove the knob from the gun and replace the knob.
    • Be aware of the rubber spacer that will come off with the knob; when you replace the knob put the spacer back in the middle around the screw hole.
结论
Ousman Jammeh
于09/17/18注册
507 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 235
