跳转到主内容
WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Chamber Gasket Replacement
你所需要的
  1. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Chamber Gasket Replacement, Pressure Regulator Chamber Gasket: 步骤 1 中的图像 1,1
    • Using a 4mm Allen wrench, remove the 4 Allen screws, 44mm in length, from the yellow cap on the back of the brad nailer.
  2. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Chamber Gasket Replacement: 步骤 2 中的图像 1,1
    • Remove the yellow cap to reveal the gasket.
    • Keep the nailer upright so the piston does not fall out. If the piston falls out, simply put it back in place.
  3. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Chamber Gasket Replacement: 步骤 3 中的图像 1,1
    • Remove the faulty gasket and replace it with a new gasket.
结论
另外一个人完成了本指南。
Ousman Jammeh
于09/17/18注册
507 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 257
