跳转到主内容
Vulcan Venture II VNB14002IE Motherboard Replacement
你所需要的
  1. Vulcan Venture II VNB14002IE Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE Motherboard Replacement: 步骤 2 中的图像 1,1
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Disconnect the 4 ribbon cables connected to the motherboard by carefully lifting up the black bar attached to the housing. Slowly slide the cable out once released.
    • Disconnect the wire connected to the motherboard.
    • Disconnect the battery by gently pulling out the cable connected to the board.
  4. Vulcan Venture II VNB14002IE Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the screws located in the corners of the board using a J00 screwdriver.
  5. Vulcan Venture II VNB14002IE Motherboard Replacement: 步骤 5 中的图像 1,1
    • Gently lift the board out of the housing without any cables still connected to the board.
    • Picture shows the housing of the motherboard after the motherboard has been removed.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 438
