跳转到主内容
Vulcan Venture II VNB14002IE I/O Board Replacement
你所需要的
  1. Vulcan Venture II VNB14002IE I/O Board Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Use a J00 screwdriver to unscrew the 10 back-plate screws.
  2. Vulcan Venture II VNB14002IE I/O Board Replacement: 步骤 2 中的图像 1,1
    • Gently separate the back panel from the laptop.
  3. Vulcan Venture II VNB14002IE I/O Board Replacement, I/O Board: 步骤 3 中的图像 1,1
    • Locate the IO board on the back panel.
  4. Vulcan Venture II VNB14002IE I/O Board Replacement: 步骤 4 中的图像 1,2 Vulcan Venture II VNB14002IE I/O Board Replacement: 步骤 4 中的图像 2,2
    • Locate the ribbon connector on the IO board, and lift the black bar closest the the ribbon.
    • Pull the ribbon cable away from the connector, releasing it.
  5. Vulcan Venture II VNB14002IE I/O Board Replacement: 步骤 5 中的图像 1,2 Vulcan Venture II VNB14002IE I/O Board Replacement: 步骤 5 中的图像 2,2
    • Locate the screws on the IO panel, and use the J00+ bit to unscrew them.
  6. Vulcan Venture II VNB14002IE I/O Board Replacement: 步骤 6 中的图像 1,1
    • The IO Board is now safe to remove from the computer.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 15
总计 520
