跳转到主内容
VuPoint DC-ST210-VP Shutter Button Replacement
你所需要的
  1. VuPoint DC-ST210-VP Shutter Button Replacement, Turn Off/Remove Batteries: 步骤 1 中的图像 1,1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP Shutter Button Replacement, Remove Screws: 步骤 2 中的图像 1,3 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Screws: 步骤 2 中的图像 2,3 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Screws: 步骤 2 中的图像 3,3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP Shutter Button Replacement, Pry Backplate Off: 步骤 3 中的图像 1,2 VuPoint DC-ST210-VP Shutter Button Replacement, Pry Backplate Off: 步骤 3 中的图像 2,2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP Shutter Button Replacement, Remove Circuit Board: 步骤 4 中的图像 1,2 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Circuit Board: 步骤 4 中的图像 2,2
    • With the back plate off, use a screw driver to remove the 6 screws shown to the left.
    • Gently separate the circuit board from frame, by prying the circuit board from base.
  5. VuPoint DC-ST210-VP Shutter Button Replacement, Move Plastic Protector: 步骤 5 中的图像 1,1
    • Using your finger rotate the dark grey piece away from the shutter button.
  6. VuPoint DC-ST210-VP Shutter Button Replacement, Remove Shutter Button: 步骤 6 中的图像 1,2 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Shutter Button: 步骤 6 中的图像 2,2
    • Remove the shutter button by gently pressing the button from the top, pushing it towards the inside of the camera. Press shutter button down and wiggle slightly until the shutter button comes loose from housing.
    • Replace as necessary.
结论
团队
Baylor, Team 8-15, Williams Fall 2014 Baylor, Team 8-15, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G15
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 18
总计 275
