跳转到主内容
VuPoint DC-ST210-VP Battery Door Cover Replacement
你所需要的
  1. VuPoint DC-ST210-VP Battery Door Cover Replacement, Turn Off/Remove Batteries: 步骤 1 中的图像 1,1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: 步骤 2 中的图像 1,3 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: 步骤 2 中的图像 2,3 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: 步骤 2 中的图像 3,3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: 步骤 3 中的图像 1,2 VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: 步骤 3 中的图像 2,2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Battery Case Screw: 步骤 4 中的图像 1,1
    • Remove the 4.5mm screw with the iFixit ph#00 screwdriver
  5. VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: 步骤 5 中的图像 1,2 VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: 步骤 5 中的图像 2,2
    • With your fingers, gently pull the two pieces of the battery case apart. At this point, the battery door should be exposed
  6. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove the Battery Cover: 步骤 6 中的图像 1,1
    • With your fingers, gently remove the battery door.
    • Now you are free to repair or replace the battery door! Follow these steps in reverse order to reassemble the camera.
结论
2等其他人完成本指南。
Elise Brown
于10/26/14注册
70 声望
创作了2篇指南
团队
Baylor, Team 8-15, Williams Fall 2014 Baylor, Team 8-15, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G15
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 18
总计 373
