跳转到主内容
加入维修社区 - 创建账户
Vtech kidizoom camera disassembly
你所需要的
  1. Vtech kidizoom camera disassembly, Vtech kidizoom camera disassembly: 步骤 1 中的图像 1,3 Vtech kidizoom camera disassembly, Vtech kidizoom camera disassembly: 步骤 1 中的图像 2,3 Vtech kidizoom camera disassembly, Vtech kidizoom camera disassembly: 步骤 1 中的图像 3,3
    • Camera
    添加评论
  2. Vtech kidizoom camera disassembly: 步骤 2 中的图像 1,3 Vtech kidizoom camera disassembly: 步骤 2 中的图像 2,3 Vtech kidizoom camera disassembly: 步骤 2 中的图像 3,3
    • push and open
    询问修复机器人
    添加评论
  3. Vtech kidizoom camera disassembly: 步骤 3 中的图像 1,3 Vtech kidizoom camera disassembly: 步骤 3 中的图像 2,3 Vtech kidizoom camera disassembly: 步骤 3 中的图像 3,3
    • Insérer un commentaire.
    询问修复机器人
    添加评论
  4. Vtech kidizoom camera disassembly: 步骤 4 中的图像 1,3 Vtech kidizoom camera disassembly: 步骤 4 中的图像 2,3 Vtech kidizoom camera disassembly: 步骤 4 中的图像 3,3
    询问修复机器人
    添加评论
  5. Vtech kidizoom camera disassembly: 步骤 5 中的图像 1,1
    询问修复机器人
    添加评论
结论
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
取消:我没有完成这个指南。
13等其他人完成本指南。
olixcomtest
于11/06/16注册
377 声望
撰写一个指南
5指南评论
In the very first step be aware that the you just need to remove the paper ring. In the photo above this is pink and on mine it was orange.
I made the mistake of thinking I had to use some force with a screwdriver, to remove the ring on the front, which resulted in me scratching the chrome ring.
Once you have removed the paper ring, you can see the screws (or they may be under the left over sticky backing to the paper but are easy to find).
These photos were extremely helpful and I was able to repair the camera.
The problem with mine, was that it would not switch on. We replaced the batteries, but still no good.
After using the above photos, I opened the camera and discovered that one of the two cables to one of the battery holders, had come loose.
In the process of resoldering the broken cable, the second battery cable also came off … mainly due to the use of VERY thin wire and minimum solder.
Anyway, the camera is now working again and my son is very happy.
Chris - 回复 分享
Thank you! It worked great with the Kidizoom Touch 5.0, Same principle. The Trigger was Stuck and with your instruction i was able to Open and fix it!
Flo - 回复 分享
Thanks! I had the newer Kidzoom touch 5.0 model. It works similar but after the same principle: First remove the camera objective ring. I could repair the (mechanical) damage…
Klausklaus - 回复 分享
Thanks a lot, also in my case the trigger button of the kidizoom touch 5.0 was stuck. I followed the instruction and was able to fix it. Thereby I scratched a bit the silver ring. This may could be prevented if the locator of the notches are known/considered while trying to remove the outer ring.
DAVID - 回复 分享
Hi, has anyone any experience of taking the Vtech Kidizoom Action Cam HD apart mine charges but will not switch on (loose wire i suspect) but i can't see how to disassemble. Cheers Alan.
Alan Mitchell - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 42
过去 30 天: 224
总计 19,591
