跳转到主内容
Vtech Touch and Swipe Baby Phone Power Switch Replacement
你所需要的
  1. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: 步骤 1 中的图像 1,2 Vtech Touch and Swipe Baby Phone Power Switch Replacement, Battery: 步骤 1 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. Vtech Touch and Swipe Baby Phone Power Switch Replacement: 步骤 2 中的图像 1,3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: 步骤 2 中的图像 2,3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: 步骤 2 中的图像 3,3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. Vtech Touch and Swipe Baby Phone Power Switch Replacement: 步骤 3 中的图像 1,3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: 步骤 3 中的图像 2,3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: 步骤 3 中的图像 3,3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: 步骤 4 中的图像 1,2 Vtech Touch and Swipe Baby Phone Power Switch Replacement, Power Switch: 步骤 4 中的图像 2,2
    • Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
  5. Vtech Touch and Swipe Baby Phone Power Switch Replacement: 步骤 5 中的图像 1,3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: 步骤 5 中的图像 2,3 Vtech Touch and Swipe Baby Phone Power Switch Replacement: 步骤 5 中的图像 3,3
    • Lift directly up to remove the switch and lay the wire down to the side.
    • Once the switch has been taken out you can remove the switch's casing.
结论
另外一个人完成了本指南。
tellocordova
于09/04/15注册
342 声望
创作了2篇指南
团队
USF Tampa, Team 2-4, Sullivan Fall 2015 USF Tampa, Team 2-4, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G4
3 名成员
创作了12篇指南
2条评论
Good work.
I have done it the same way,
the wire at the switch was bad soldered,
but it was easy to repair it and i soldered it new.
Nice.
Schwarzstein - 回复
My baby’s phone keeps turning itself off. The switch is in the ON position but it keeps turning OFF and singing the off song. I have opened the phone and even held the switch to ON but it still keeps turning OFF even without the switch moving. Any suggestions?
shakinsher - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 627
