跳转到主内容
Vtech Move and Crawl Ball Motor Replacement
你所需要的
  1. Vtech Move and Crawl Ball Motor Replacement, Battery: 步骤 1 中的图像 1,2 Vtech Move and Crawl Ball Motor Replacement, Battery: 步骤 1 中的图像 2,2
    • There are two screws that require a 4.0mm flat head screwdriver. Twist them counter clockwise to remove. When you remove them they stay contained within the blue outer case.
  2. Vtech Move and Crawl Ball Motor Replacement: 步骤 2 中的图像 1,3 Vtech Move and Crawl Ball Motor Replacement: 步骤 2 中的图像 2,3 Vtech Move and Crawl Ball Motor Replacement: 步骤 2 中的图像 3,3
    • Pry the batteries out with your finger. When you replace them be sure to orient them correctly according to the markings in the slots. Match the plus symbol on the battery to the plus symbol in the slot.
  3. Vtech Move and Crawl Ball Motor Replacement, Motor: 步骤 3 中的图像 1,3 Vtech Move and Crawl Ball Motor Replacement, Motor: 步骤 3 中的图像 2,3 Vtech Move and Crawl Ball Motor Replacement, Motor: 步骤 3 中的图像 3,3
    • Remove 6 screws in order to pop off the outer shell and reach the inside components.
  4. Vtech Move and Crawl Ball Motor Replacement: 步骤 4 中的图像 1,3 Vtech Move and Crawl Ball Motor Replacement: 步骤 4 中的图像 2,3 Vtech Move and Crawl Ball Motor Replacement: 步骤 4 中的图像 3,3
    • Remove the motor by lifting it out of the shell, and find the attached wires at both ends: the circuit board and the motor itself. Use the soldering iron to remove the existing attachments by heating the solder joint with the solder iron tip while pulling on the wire.
    • Make sure the motor is aligned over the correct holes during reassembly.
结论
另外一个人完成了本指南。
William Jones
于09/04/15注册
222 声望
创作了2篇指南
团队
USF Tampa, Team 2-1, Sullivan Fall 2015 USF Tampa, Team 2-1, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G1
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,720
