跳转到主内容
Vtech InnoTab 3S Speaker Replacement
你所需要的
  1. Vtech InnoTab 3S Speaker Replacement, Rear Panel: 步骤 1 中的图像 1,3 Vtech InnoTab 3S Speaker Replacement, Rear Panel: 步骤 1 中的图像 2,3 Vtech InnoTab 3S Speaker Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Speaker Replacement: 步骤 2 中的图像 1,2 Vtech InnoTab 3S Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Speaker Replacement: 步骤 3 中的图像 1,3 Vtech InnoTab 3S Speaker Replacement: 步骤 3 中的图像 2,3 Vtech InnoTab 3S Speaker Replacement: 步骤 3 中的图像 3,3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Speaker Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Speaker Replacement, Motherboard: 步骤 5 中的图像 1,2 Vtech InnoTab 3S Speaker Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
    • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
    • Remove the six 3 mm screws securing the battery clip.
  6. Vtech InnoTab 3S Speaker Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
    • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
    • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
  7. Vtech InnoTab 3S Speaker Replacement, Speaker: 步骤 7 中的图像 1,2 Vtech InnoTab 3S Speaker Replacement, Speaker: 步骤 7 中的图像 2,2
    • Looking at the front of the motherboard, the speakers are located in the bottom left of the device. They are shaped like a large black circle.
    • Using a soldering iron, heat the connections securing the speakers to the motherboard of the device.
    • Remove the connections on the motherboard to detach the speaker.
    • Avoid forceful movements when soldering to prevent damage of device components and avoid personal injury.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 8-2, Eyestone Fall 2015 USF Tampa, Team 8-2, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G2
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 661
