跳转到主内容
Vtech InnoTab 3S Rear Panel Replacement
你所需要的
  1. Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: 步骤 1 中的图像 1,3 Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: 步骤 1 中的图像 2,3 Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Rear Panel Replacement: 步骤 2 中的图像 1,2 Vtech InnoTab 3S Rear Panel Replacement: 步骤 2 中的图像 2,2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Rear Panel Replacement: 步骤 3 中的图像 1,3 Vtech InnoTab 3S Rear Panel Replacement: 步骤 3 中的图像 2,3 Vtech InnoTab 3S Rear Panel Replacement: 步骤 3 中的图像 3,3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Rear Panel Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
结论
Karina Garcia
于08/30/15注册
824 声望
创作了6篇指南
团队
USF Tampa, Team 8-2, Eyestone Fall 2015 USF Tampa, Team 8-2, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G2
4 名成员
创作了9篇指南
一条评论
too dumb i tryed 7 times it didnt work i reat this 1000000-/10
Kyron Ostrander - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 12
总计 625
