跳转到主内容
Vtech InnoTab 3S Camera Replacement
你所需要的
  1. Vtech InnoTab 3S Camera Replacement, Rear Panel: 步骤 1 中的图像 1,3 Vtech InnoTab 3S Camera Replacement, Rear Panel: 步骤 1 中的图像 2,3 Vtech InnoTab 3S Camera Replacement, Rear Panel: 步骤 1 中的图像 3,3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Camera Replacement: 步骤 2 中的图像 1,2 Vtech InnoTab 3S Camera Replacement: 步骤 2 中的图像 2,2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Camera Replacement: 步骤 3 中的图像 1,3 Vtech InnoTab 3S Camera Replacement: 步骤 3 中的图像 2,3 Vtech InnoTab 3S Camera Replacement: 步骤 3 中的图像 3,3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Camera Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Camera Replacement, Camera: 步骤 5 中的图像 1,2 Vtech InnoTab 3S Camera Replacement, Camera: 步骤 5 中的图像 2,2
    • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
    • The connection between the motherboard and the camera is located at the near the top of the device.
    • Remove the camera and the connecting wire from the the clip and attach the replacement cameras connection to the latch on the motherboard.
    • Carefully lower the latch until you hear a click to secure the new camera to the device.
    • Pulling or tugging on the connection between the camera and the circuit board may cause damage to the connection.
结论
2等其他人完成本指南。
Karina Garcia
于08/30/15注册
878 声望
创作了6篇指南
团队
USF Tampa, Team 8-2, Eyestone Fall 2015 USF Tampa, Team 8-2, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G2
4 名成员
创作了9篇指南
4指南评论
Where do you get the replacement camera? I can't find them online.
rongennero - 回复
I just did this whole thing...hoping it was a reset to the camera or something, but no, you need a replacement camera. Might be helpful to add that to the PARTS NEEDED part at the top, instead of saying "no parts required." UUGHHHH!
jpimash - 回复
Where can i buy the camera?
Stephan Meyer - 回复
kind of useless to post a replacement guide without suggesting a source for that replacement!!
Glen Fletcher - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 2,126
