跳转到主内容
Voluas VL001 Motor Assembly Gears Replacement
你所需要的
  1. Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: 步骤 1 中的图像 1,3 Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: 步骤 1 中的图像 2,3 Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: 步骤 1 中的图像 3,3
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
  2. Voluas VL001 Motor Assembly Gears Replacement, Battery: 步骤 2 中的图像 1,3 Voluas VL001 Motor Assembly Gears Replacement, Battery: 步骤 2 中的图像 2,3 Voluas VL001 Motor Assembly Gears Replacement, Battery: 步骤 2 中的图像 3,3
    • Place your pet feeder upside down.
    • Squeeze the lock and remove the battery cover.
    • Remove the three 1.5V D alkaline batteries.
  3. Voluas VL001 Motor Assembly Gears Replacement, Housing: 步骤 3 中的图像 1,3 Voluas VL001 Motor Assembly Gears Replacement, Housing: 步骤 3 中的图像 2,3 Voluas VL001 Motor Assembly Gears Replacement, Housing: 步骤 3 中的图像 3,3
    • Insert a metal spudger under the adhesive part of each rubber foot.
    • Pry the foot off.
  4. Voluas VL001 Motor Assembly Gears Replacement: 步骤 4 中的图像 1,2 Voluas VL001 Motor Assembly Gears Replacement: 步骤 4 中的图像 2,2
    • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
    • These holes were previously covered by the rubber feet.
    • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
  5. Voluas VL001 Motor Assembly Gears Replacement: 步骤 5 中的图像 1,1
    • Turn the device over so it is oriented right-side up.
    • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
  6. Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: 步骤 6 中的图像 1,3 Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: 步骤 6 中的图像 2,3 Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: 步骤 6 中的图像 3,3
    • Using a Phillips #2 screwdriver, remove the six screws that hold the motor housing on to the device.
  7. Voluas VL001 Motor Assembly Gears Replacement: 步骤 7 中的图像 1,1
    • Lift the electric motor from its housing and move it aside.
  8. Voluas VL001 Motor Assembly Gears Replacement: 步骤 8 中的图像 1,2 Voluas VL001 Motor Assembly Gears Replacement: 步骤 8 中的图像 2,2
    • Use the tweezers to remove the first gear that is placed on top.
  9. Voluas VL001 Motor Assembly Gears Replacement: 步骤 9 中的图像 1,2 Voluas VL001 Motor Assembly Gears Replacement: 步骤 9 中的图像 2,2
    • Use the tweezers to gently remove the second gear.
  10. Voluas VL001 Motor Assembly Gears Replacement: 步骤 10 中的图像 1,2 Voluas VL001 Motor Assembly Gears Replacement: 步骤 10 中的图像 2,2
    • Use the tweezers to gently remove the third gear.
结论
Jade Thomson
于01/30/24注册
699 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 32
