跳转到主内容
加入维修社区 - 创建账户
Volleyball Valve Replacement
你所需要的
  1. Volleyball Valve Replacement, Valve: 步骤 1 中的图像 1,1
    • Bend a thin metal wire into a hook.
    • This is what we will be using to wiggle the air valve out.
  2. Volleyball Valve Replacement: 步骤 2 中的图像 1,1
    • Insert the wire into the valve and use it to hook and pull out the valve as much as possible. .
    • This process might take awhile depending how broken the valve is.
  3. Volleyball Valve Replacement: 步骤 3 中的图像 1,1
    • Once a piece of the valve is sticking out, use the needle nose pliers to pull out the valve.
  4. Volleyball Valve Replacement: 步骤 4 中的图像 1,1
    • With your new valve, place it to the hole where the previous valve was, and use the screwdriver to push it in until it is flush with the surface of the ball.
  5. Volleyball Valve Replacement: 步骤 5 中的图像 1,1
    • You are done! The volleyball valve has been replaced and should not let any air out.
结论
Justin Nadela
于01/16/22注册
121 声望
撰写一个指南
团队
1指南评论
Thanks for this!!
Can you please let me know what valves to buy?
(my email address is sendtojfk@gmail.com)
Thanks!
Justin Kern - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 37
过去 30 天: 125
总计 5,175
