更好的介绍
通过完成或修改其开头介绍以改善本指南。
简介
转到步骤 1 ↓Hello! This guide will help you replace the Wi-Fi antenna in your Vizio VTAB1008.
你所需要的
工具
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Using the blue spudger/prying tool remove antenna connectors by prying them up from the motherboard.
