跳转到主内容
Vizio VTAB1008 Wi-Fi Antenna Replacement
你所需要的
  1. Vizio VTAB1008 Wi-Fi Antenna Replacement, Vizio VTAB1008 Back Cover Removal: 步骤 1 中的图像 1,2 Vizio VTAB1008 Wi-Fi Antenna Replacement, Vizio VTAB1008 Back Cover Removal: 步骤 1 中的图像 2,2
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Vizio VTAB1008 Wi-Fi Antenna Replacement: 步骤 2 中的图像 1,1
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Vizio VTAB1008 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 步骤 3 中的图像 1,3 Vizio VTAB1008 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 步骤 3 中的图像 2,3 Vizio VTAB1008 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 步骤 3 中的图像 3,3
    • Using the blue spudger/prying tool remove antenna connectors by prying them up from the motherboard.
  4. Vizio VTAB1008 Wi-Fi Antenna Replacement: 步骤 4 中的图像 1,3 Vizio VTAB1008 Wi-Fi Antenna Replacement: 步骤 4 中的图像 2,3 Vizio VTAB1008 Wi-Fi Antenna Replacement: 步骤 4 中的图像 3,3
    • Remove connectors from the back cover by gently prying.
    • Connectors are glued down, but copper can be removed from the backing with light pulling.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 15
总计 240
