跳转到主内容
加入维修社区 - 创建账户
Vizio VTAB1008 Front Facing Camera Replacement
你所需要的
  1. Vizio VTAB1008 Front Facing Camera Replacement, Vizio VTAB1008 Back Cover Removal: 步骤 1 中的图像 1,2 Vizio VTAB1008 Front Facing Camera Replacement, Vizio VTAB1008 Back Cover Removal: 步骤 1 中的图像 2,2
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
    询问修复机器人
    添加评论
  2. Vizio VTAB1008 Front Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
    询问修复机器人
    添加评论
  3. Vizio VTAB1008 Front Facing Camera Replacement, Front Facing Camera and Light Sensor Board: 步骤 3 中的图像 1,2 Vizio VTAB1008 Front Facing Camera Replacement, Front Facing Camera and Light Sensor Board: 步骤 3 中的图像 2,2
    • Remove the screw with the J1 screwdriver or screw bit.
    • The screw has a 3.66 mm head and is 3.5 mm tall.
    询问修复机器人
    添加评论
  4. Vizio VTAB1008 Front Facing Camera Replacement: 步骤 4 中的图像 1,3 Vizio VTAB1008 Front Facing Camera Replacement: 步骤 4 中的图像 2,3 Vizio VTAB1008 Front Facing Camera Replacement: 步骤 4 中的图像 3,3
    • Lift the flap hiding the second screw.
    • Remove the screw by using the J1 screwdriver.
    询问修复机器人
    添加评论
  5. Vizio VTAB1008 Front Facing Camera Replacement: 步骤 5 中的图像 1,3 Vizio VTAB1008 Front Facing Camera Replacement: 步骤 5 中的图像 2,3 Vizio VTAB1008 Front Facing Camera Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Disconnect the black and red cable connector from the camera strap.
    • Using tweezers may help to grab the small connector flanges.
    询问修复机器人
    添加评论
  6. Vizio VTAB1008 Front Facing Camera Replacement: 步骤 6 中的图像 1,3 Vizio VTAB1008 Front Facing Camera Replacement: 步骤 6 中的图像 2,3 Vizio VTAB1008 Front Facing Camera Replacement: 步骤 6 中的图像 3,3
    • Disconnect the ribbon cable from the camera circuit board by lifting it away from the circuit board.
    • A spudger may help with leverage when removing the ribbon cable.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 40
总计 427
