跳转到主内容
加入维修社区 - 创建账户
Vizio VTAB1008 Digitizer (Touchscreen) Replacement
你所需要的
  1. Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Vizio VTAB1008 Back Cover Removal: 步骤 1 中的图像 1,2 Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Vizio VTAB1008 Back Cover Removal: 步骤 1 中的图像 2,2
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
    询问修复机器人
    添加评论
  2. Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 步骤 2 中的图像 1,1
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
    询问修复机器人
    添加评论
  3. Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Digitizer/Touch Screen: 步骤 3 中的图像 1,3 Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Digitizer/Touch Screen: 步骤 3 中的图像 2,3 Vizio VTAB1008 Digitizer (Touchscreen) Replacement, Digitizer/Touch Screen: 步骤 3 中的图像 3,3
    • Remove the two screws present using the J1 Screw bit.
    • The screw has a head size of 4.3 mm and is 3 mm tall.
    询问修复机器人
    添加评论
  4. Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 步骤 4 中的图像 1,3 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 步骤 4 中的图像 2,3 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 步骤 4 中的图像 3,3
    • Remove the two brackets accompanying screws by lifting them up and away from the screen.
    • Brackets are 8.5 mm by 6.55 mm.
    询问修复机器人
    添加评论
  5. Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 步骤 5 中的图像 1,3 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 步骤 5 中的图像 2,3 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 步骤 5 中的图像 3,3
    • Separate the screen digitizer from the display screen, noting the placement of the quick disconnect ribbon cable.
    • Use a spudger if necessary to assist in the separation.
    询问修复机器人
    添加评论
  6. Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 步骤 6 中的图像 1,2 Vizio VTAB1008 Digitizer (Touchscreen) Replacement: 步骤 6 中的图像 2,2
    • The digitizer should now be able to be freely removed.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 23
总计 1,105
