跳转到主内容
加入维修社区 - 创建账户
Vizio VTAB1008 Charging Port Replacement
你所需要的
  1. Vizio VTAB1008 Charging Port Replacement, Vizio VTAB1008 Back Cover Removal: 步骤 1 中的图像 1,2 Vizio VTAB1008 Charging Port Replacement, Vizio VTAB1008 Back Cover Removal: 步骤 1 中的图像 2,2
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
    询问修复机器人
    添加评论
  2. Vizio VTAB1008 Charging Port Replacement: 步骤 2 中的图像 1,1
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
    询问修复机器人
    添加评论
  3. Vizio VTAB1008 Charging Port Replacement, Charging Port: 步骤 3 中的图像 1,3 Vizio VTAB1008 Charging Port Replacement, Charging Port: 步骤 3 中的图像 2,3 Vizio VTAB1008 Charging Port Replacement, Charging Port: 步骤 3 中的图像 3,3
    • Remove the motherboard by unscrewing the four securing screws with a J1 Phillip's head screwdriver.
    • 3 of the screws are clearly visible while the 4th is hidden by black tape on the upper left corner of the motherboard.
    询问修复机器人
    添加评论
  4. Vizio VTAB1008 Charging Port Replacement: 步骤 4 中的图像 1,3 Vizio VTAB1008 Charging Port Replacement: 步骤 4 中的图像 2,3 Vizio VTAB1008 Charging Port Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove both antenna connectors with a blue opening tool/tweezers.
    询问修复机器人
    添加评论
  5. Vizio VTAB1008 Charging Port Replacement: 步骤 5 中的图像 1,3 Vizio VTAB1008 Charging Port Replacement: 步骤 5 中的图像 2,3 Vizio VTAB1008 Charging Port Replacement: 步骤 5 中的图像 3,3
    • Remove the ribbon connector at the top of the motherboard using the opening tool.
    询问修复机器人
    添加评论
  6. Vizio VTAB1008 Charging Port Replacement: 步骤 6 中的图像 1,2 Vizio VTAB1008 Charging Port Replacement: 步骤 6 中的图像 2,2
    • Remove the connector at the top of the motherboard by pulling the connector away from the motherboard with fingers or tweezers.
    询问修复机器人
    添加评论
  7. Vizio VTAB1008 Charging Port Replacement: 步骤 7 中的图像 1,3 Vizio VTAB1008 Charging Port Replacement: 步骤 7 中的图像 2,3 Vizio VTAB1008 Charging Port Replacement: 步骤 7 中的图像 3,3
    • Remove the connector at the side of the motherboard using the opening tool.
    • The connector is covered by a piece of black tape.
    询问修复机器人
    添加评论
  8. Vizio VTAB1008 Charging Port Replacement: 步骤 8 中的图像 1,2 Vizio VTAB1008 Charging Port Replacement: 步骤 8 中的图像 2,2
    • Remove the red and black wire connector from the motherboard using either fingers or tweezers.
    询问修复机器人
    添加评论
  9. Vizio VTAB1008 Charging Port Replacement: 步骤 9 中的图像 1,3 Vizio VTAB1008 Charging Port Replacement: 步骤 9 中的图像 2,3 Vizio VTAB1008 Charging Port Replacement: 步骤 9 中的图像 3,3
    • Flip the motherboard over.
    • Directly underneath the USB Charging connector will be four solder points that need to be undone in order to remove the charging port.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 43
总计 1,611
