跳转到主内容
Vizio Tablet Micro USB Charging Port Replacement
你所需要的
  1. Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: 步骤 1 中的图像 1,3 Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: 步骤 1 中的图像 2,3 Vizio Tablet Micro USB Charging Port Replacement, Micro USB Charging Port: 步骤 1 中的图像 3,3
    • Begin by using the plastic opening tool to take off the back of the tablet.
    • Starting from the sides can make the process easier.
  2. Vizio Tablet Micro USB Charging Port Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to disconnect the LCD screen.
  3. Vizio Tablet Micro USB Charging Port Replacement: 步骤 3 中的图像 1,1
    • Use the plastic opening tool to disconnect the camera.
  4. Vizio Tablet Micro USB Charging Port Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to disconnect both of the volume buttons.
  5. Vizio Tablet Micro USB Charging Port Replacement: 步骤 5 中的图像 1,2 Vizio Tablet Micro USB Charging Port Replacement: 步骤 5 中的图像 2,2
    • Then, remove all four of the 2.3 mm Phillips screws.
  6. Vizio Tablet Micro USB Charging Port Replacement: 步骤 6 中的图像 1,1
    • Remove the circuit board from the platform.
  7. Vizio Tablet Micro USB Charging Port Replacement: 步骤 7 中的图像 1,1
    • Remove the USB port from the circuit board.
  8. Vizio Tablet Micro USB Charging Port Replacement: 步骤 8 中的图像 1,1
    • Insert the new USB port onto the circuit board.
  9. Vizio Tablet Micro USB Charging Port Replacement: 步骤 9 中的图像 1,1
    • Lastly, fuse the USB port back onto the circuit board.
结论
另外一个人完成了本指南。
Jose
于05/31/16注册
125 声望
撰写一个指南
一条评论
Thank you it was very helpful simple and straight to the point
sirhc89chris - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 936
