跳转到主内容
加入维修社区 - 创建账户
Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna Replacement
你所需要的
    1. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
      询问修复机器人
      添加评论
    2. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 步骤 2 中的图像 1,1
      • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
      询问修复机器人
      添加评论
    3. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 步骤 3 中的图像 1,1
      • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
      询问修复机器人
      添加评论
    1. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement, Top Speaker + WIFI Antenna: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      • During this step, avoid pulling on the red and black wires as they can be easily damaged. Instead, grab only the plug itself.
      • Use the tweezers to grab the power plug connected to the red and black wires. Disconnect the plug by pulling the tweezers away from the device.
      询问修复机器人
      添加评论
    2. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 步骤 5 中的图像 1,3 Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 步骤 5 中的图像 2,3 Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 步骤 5 中的图像 3,3
      • Place the flat end of the black plastic spudger under the locking tab that holds the tail end of the black ribbon in place. Pry upwards unlocking the tail of the black ribbon. Use the tweezers to remove the black ribbon from the plug.
      询问修复机器人
      添加评论
    3. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 步骤 6 中的图像 1,3 Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 步骤 6 中的图像 2,3 Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 步骤 6 中的图像 3,3
      • Remove the three 3mm screws holding the WIFI antennae in the device. Use the tweezers to grab and remove the metal plate securing the antennae.
      • Two of the screws are silver, while one is black.
      询问修复机器人
      添加评论
    4. Vizio SmartCast Tablet Remote XR6P Top Speaker + WIFI Antenna  Replacement: 步骤 7 中的图像 1,1
      • Remove the WIFI antennae from the device and replace.
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 549
