跳转到主内容
加入维修社区 - 创建账户
Vizio SmartCast Tablet Remote XR6P Power Button Replacement
你所需要的
    1. Vizio SmartCast Tablet Remote XR6P Power Button Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
      询问修复机器人
      添加评论
    2. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: 步骤 2 中的图像 1,1
      • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
      询问修复机器人
      添加评论
    3. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: 步骤 3 中的图像 1,1
      • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
      询问修复机器人
      添加评论
    1. Vizio SmartCast Tablet Remote XR6P Power Button Replacement, Power Button: 步骤 4 中的图像 1,1
      • Using the pointy end of the black plastic spudger, carefully remove the black tape covering the plug.
      询问修复机器人
      添加评论
    2. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: 步骤 5 中的图像 1,2 Vizio SmartCast Tablet Remote XR6P Power Button Replacement: 步骤 5 中的图像 2,2
      • Use the flat end of the spudger to pry the ribbon holder upwards.
      询问修复机器人
      添加评论
    3. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: 步骤 6 中的图像 1,1
      在这个步骤中使用的工具:
      • Obtain the tweezers and gently pull the black ribbon until it comes out of the holder.
      询问修复机器人
      添加评论
    4. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: 步骤 7 中的图像 1,1
      • Continue pulling the black tab until you have completely removed the power button from the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
1指南评论
you can perform the operation since when you shake the tablet listening that something moves in the area of ​​the power button, the tablet does not turn on by pressing the button, I have to connect the charger and now press the button and the tablet turns on, already on the device pressed power button and the menu appears shutdown and reboot, actually I don't know what the problem is.
miguel anhel Hernandez - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 25
总计 772
